Well after using a BOV (Blow off Valve) on my turbo for 2 weeks I am finally going to share my information. I bought 4 of them to try they were only $5. 00 apiece and made very well. Here they are from www.McMaster-Carr.com
ITEM #4772K2 1/8" NPT
$4. 89
Economy Brass Pop-Safety Valves for Air
• Set Pressure: See "To Order"
• Maximum Temperature: 250° F
Low-cost protection for compressed air systems. Valves are made of brass with a stainless steel ball. Ball is seated on a precision-machined brass seat. Seat is metal-to-metal.
Connections: NPT male bottom inlet and vented side outlet.
To Order: Valves are available at set pressures from 5 to 100 psi in 5 psi increments. Please specify pressure setting.
Our turbo has a 1/8" NPT where are boost elbow goes. I just screwed it in and put a rubber plug over my wastegate line. I ordered a 30,35,40,45. I think the one for me that worked best is the 35. And it does keep me from barking the turbo. I have an auto so it is harder anyway but when I am on 6/6 it is not hard to do if I get on it hard and let off quickly. Hope this helps some of you that are frustrated with there wastegate like I was. And you can here it pop off at 35psi.
$4. 89
