i have a wolfpack toyhauler with an onboard 4000 watt onan genset
the problem im having is about 2 yrs in the making
while at a steam engine show the gen stopped working
it was still running just no power for the rv
checked breakers all were good
in the gen comprtmnt a flex line comes out to a 4" box thats mounted to floor
on top of that box is a push button 30 amp breaker that was popped up
reset it all is good
from time 2 time it would pop and i would reset
i just figured it was under heavy load b/c it would happen on very hot days and the a/c was running
now it happens almost all the time like every 10 minutes
i crawled in the pass thru compartment and opened the 4" box
the neutral wire from gen to neutral wire of the rv was melted at the wire nut
cut off melted piece and reconnected with new wire nut & taped conections
still pops push button breaker
but now also pops 20 amp breaker inside rv
and also will just stop sending power to rv
gen still runs but it seems like the 110v/12v transfer switch is tripping
b/c it will switch from 110 fixtures running then loses 110 power for a couple of minutes and then "resenses" gen power and kicks back in
thanks in advance
thanks in advance
