yes
Yes you can... . I did it for awhile just for comparsions and finally just went to pre-turbo... . I can't remember the name if the switch, however, I got it a Radio shack. . It's single pole toggle which is double legged. . has 6-connectors on the bottom... It gets tricky, when you wire as each probe will have seperate wires going to each side of switch and back to gauage... . then all you do is switch toggle and the EGT gauage will either read pre or post turbo depending on what position the toggle switch is on ... . Check archives, as someone once posted a diagram on how to wire... . Maybe someone else will chime in.
Steve
