I also installed my driveshaft on Saturday. I ordered the part from DogHouse Diesel as well... ... It is nice to know that OUTSTANDING customer service is alive and well in some organizations.Thanks Rich!
My driveline has started to vibrate a little more than usual. I was under the truck today and sure enough, my center bearing has a little play and one of my U joints has developed a little play as well.
Rather than replace those parts, I just ordered the one piece drive shaft from Doghouse. Rich says it comes complete with U joints and is ready to bolt in so I won't have to buy anything else to get rid of my problems.
Do you know if it comes with sealed or greasable u-joints??
The u-joints are sealed.
You can replace them with a Spicer, Precision, or other greaseable joint, but you have to machine . 010" off the end caps for them to fit correctly.
The standard Spicer type joints are just slightly too large to fit correctly.
If someone gets one here at the shop and just REALLY wants the greaseables, we can put the Spicer caps in the mill and take the . 010" off and they're fine.
Because you are extending the distance between the joints by going with the one piece shaft, you cut the operating angle almost in half. This puts a lot less stress on the u-joints and makes the greaseables less necessary.
But, unless you routinely submerge the joints under water, you don't need the greaseables.
My driveshaft came about noon today. Fast delivery from Doghouse! I installed it this afternoon.
As expected, taking out the old parts took a lot longer than installing the new. That old shaft was really heavy compared to the new one.
After I was done I drove about 10 miles on the expressway at 70 mph. Everything was smooth and nothing fell off... :-laf
