91. 5 truck has been giving me starting problems. Quite weird symptoms. If the truck gets under one half tank of fuel, it takes a while to fire off when cranking. Full tank seems normal. If I park it on a steep hill, (nose up) the symptoms worsen considerably. Then engine will crank till the primary pump gets fuel to the injection pump and off we go running perfect after some skipping and smoke. I see no external leaks on the injection pump but its like there is an air leak that makes it loose its prime. Pump has 180,000 miles but runs great after it starts. ANy similar situations that someone else has figured out? Thanks for any help.
