Engine/Transmission (1994 - 1998) oops:(.... any sugestions?
Engine/Transmission (1998.5 - 2002) ECM Troubleshooting
Engine/Transmission (1998.5 - 2002) new or used ECM
well i pulled my plate cut it adjusted the tension on the afc diaphram and decided to check my govenor lever and while i was tryin to make the adjustment the screw fell out of the arm:( but..... i got it out of the pump pretty easy now i need to get it back in the arm andybody got any suggestions?Oo.
Use small piece of rubber hose on a screwdriver to get it back started again, then adjust as needed. Sounds like you got really lucky fishing it out of the pump :eek:
Dave
i'll have to try that maybe apiece of vaccum tubing or something and man i know! i'm not even sure how it happened i was tightening the locknut down and when i went to pull the ratchet out it came out too and hell the lock nut wasn't tight when i opened it up either not even close i could turn it with the tip of my finger before i started
I have dropped a piece or two in the pump from time to time :-laf
It sure is a sick feeling in your stomach :eek:
Good luck,
Dave
ok i got it in and theres something wrong with the lever i think i can't tighten the lock screw so i might have to take it into the shop here shortly but... . with the dirty made 0plate and afc tweaks the trannys not gonna last long but..... i've finally got caol and enough grunt to pull hills:D and jesus diesel is 3. 45 here today!!!!
