An automatic locker for a street driven, two wheel drive truck is a real, repeat REAL bad idea. I had a Detroit Locker in my Grand Cherokee that I wheeled, and it was a little scary sometimes (shorter wheelbase. ) Banked off-ramps with ice and snow were the worst. You really have to change the way you drive with a locker (Lockright, Detroit, etc. ) With the ridiculous lift (6"+) and the Detroit locker, my wife wouldn't ever drive it.
An ARB locker would be real nice, as you choose when it is a spool, and when it is an open diff. Just don't forget when its engaged on pavement (axle shafts will go POW!) The draw back is the huge expense ($650 for the locker, and $200 for the compressor) and the fact that the install is not a DIY, so $500 or more for installation. OUCH, $1300!!!!
I suggest that you put in a Detroit TrueTrac, which is a gear driven limited slip (very nice. ) Installing one without a ring&pinion change is really no big deal. I can borrow the tools necessary to make sure the setup before and and after is correct. If we remove the current carrier bearings, the shims are most likely not going to change. With new bearings, the preload is a little different, but shim kits are pretty cheap. With the full-float rear axles, changing the diff doesn't even require removing the wheels!
So, when do we have the BOMB session????
