Wolfy:
I agree with this sentiment, completely:
"... To really work out the battery lifetime/dollar relationship, along with the claimed use-advantages of the AGM's, using the 50% discharge limit, takes a bit of calculator work. But when the failure/replacement rate of neglected regular batteries is kept in mind, along with the potential for acid spills/fumes, etc. , The dependability, lifetime cost, capacity and durability of the Lifelines won out for me... "
I've read several articles about the fact that AGM batteries of all stripes are finicky about their charging requirements: In fact, it's well advertised that they can be damaged -- or even ruined, completely -- as a result of improper charging procedures.
I suspect that, in the majority of cases, premature AGM battery failure (especially in instances where customers report, say, eight consecutive battery failures in a row) may be a case of improper charging technique, defective charging equipment, etc.
I'm not making any accusations, nor pointing any fingers, it's just that it's been well documented -- and the manufacturers readily advertise the fact -- that AGM batteries are susceptible to damage resulting from charging errors.
In my case, as in yours, I've developed a mistrust for lead-acid batteries in the severe conditions (altitudes, temps, distance from service centers, etc. ) I live in. Colorado isn't the North Pole, but it's plenty cold; it's not the Sahara, but it can get plenty hot. I can't explain the pertinent physics, but water-filled batteries seem to have more problems at 10,000 feet (where I work much of the time) than their AGM cousins.
I, too, have grown tired of replacing parts that've been damaged by leaking batteries: My list ('97 Dodge CTD) includes cruise-control components, horn leads, light relays, and so on. I spend a lot of time on rough roads, and liquid-filled batteries get subjected to constant agitation (picture Waring blender on "puree"), so -- "discretion being the better part of valor" -- it seems sensible, to me, to remove the OEM batteries and replace them with something more dependable and better suited to my needs.
I have a lot of family in Colorado, many of whom drive SUVs, live in less severe settings (son in Denver, married daughter in Boulder), so my OEMs will not go to waste.
What I find humorous is examples of individuals who'll decry my waste at removing old-technology batteries, then turn around and slap all sorts of unnecessary gear on their own trucks -- always with a ready rationalization about own their special needs. I worked the same, '97 2500 CTD for 10 years, and resisted the urge to replace it every time the manufacturer changed upholstery colors. If you want to see examples of waste on this site (or thread), it's easy to find them without too much eye strain.
In my experience (DISCLAIMER: AND everybody's experience is DIFFERENT) batteries and tires are the components that have caused me the most grief over my 40 year driving history.
Since I keep my vehicles, and drive them 'till the proverbial "doors fall off," I can justify buying/installing batteries and tires that are rated to last for the better part of a decade, and pass the OEM stuff along to my kids.
Wolfy, btw, I have replaced the OEM tires with SUMITOMO ST918 225/70R 19. 5s and American Eagle 19. 5s. This is a fantastic combination, because the
diameter of the tire/wheel setup exactly matches the factory OEMs, and the weight of the pairing is within 4 lbs per corner, too. The SUMITOMO tires are 14-ply commercial duty, but they only weigh 50 pounds, because they have short, square side-walls. The truck almost looks like it's been set up for racing (picture Miami Vice bobbing beaner vehicle) because the wheel/tire combination has such a low-profile appearance. The ride, however, is not harsh (tires inflated to 75 pounds), and the handling on these curvey mountain roads is fantastic.
I purchased from my local "Big-O" Tire, and the tires have a lifetime damage replacement (non "pro-rated") guarantee, with free balancing, rotation, swapping (winter/summer) etc. from all stores, nationwide. The store ordered the steel inners (for the dual-rears) from Rickson, which I appreciated, too.
I will post pictures, soon.
