Details here: TDR Privileges
Can you replicate at will? Under a load and over 2500 rpms I am always at 1 to 1. 3-5 depending on throttle position. Unloaded its much less but still a spike starting at 2500.
I'd be curious to see what the drive pressure is on the front cylinders without the waste gate. You're measuring EGT on the wastegated cylinders, how much higher would it be on the non-wastegated cylinders?
I measure DP on the front cylinder, so I will be able to see it if it drops when the WG opens. I have yet to hit the boost required to open it. But I bet it drops nearly the same as the aft bank. It's pretty much 1:1 or better in all the driving I have done so far.
I honestly don't think EGT's will be effected by the WG location during WG operation. But I don't intend to spend much time at all in the 35-37 psi range, so I am not sure it will be an issue regardless.
