Ordering codes for Camper package to go on a 3500 6.7l 4x4 SRW?
Question about "coolant level low" and CEL
I've been checking back threads and noticed there are Codes for options to include, when ordering your Dodge 3500 SRW.
These codes have numbers and letters.
I did not see a coded number for the Camper package. Is there such a code number
when you order a Dodge 3500 to include for options for your truck?
Is there a list i can find on line, somewhere? I went to Ram Trucks.com but didn't see any codes listed.
Thank you, for your responses.
Scott
As far as I know, RAM hasn't offered a camper package on the 4th Gen.
I think that when they did offer it in the past, it was a rear sway bar and different springs. You can add things like that yourself.
I never saw such an option when searching out info before buying my 2013. Given the suspension and other capabilties of the new 3500s, I don't see any need for a further beef-up to hold a camper. My 6' bed SRW 3500 came with a camper sheet rating it for 2800 lb.
Thank you for the reply Dieselnerd.
I'm planning to add Hellwing sway bars and Bilsten shocks after i get my truck, anyway no big deal. I will ask the dealer when i order to add a forward bed power connection to plug in my camper.
That way i can free up the hitch connection for towing a small trailer if, i decide to.
Scott
Thank you Joe,
I plan to get the 8' bed in my Dodge 3500 so it should be more. Should be able to load a Wolf Creek 850 non-slide camper, and add Hellwing sway bars and Bilsten shocks after i get my truck. I'll be sure when i order at the dealer to ensure my truck is rated for a camper.
Scott
I ordered my C&C with front super heavy duty springs, you might want to ask the fleet sales if option still exsists. I'm on a business trip in Vegas, when I get home I'll look up the code numbers/letters for you.
Appreciate the information RVTRKN.
Scott
Thank you for the information. I'll make sure I order the Fifth Wheel/Gooseneck prep.
Scott
This plug is in the rear of the bed, no help for a TC. Buying an aftermarket in-line plug to install in the front of the bed for a TC is easy.
I chose to adapt my TC wire to use the available rear bumper jack as I don't ever tow.
Also, if you order the 3500 with the Snow Plow prep option, you do not get the camper certification sheet as it becomes "Not recommended for a TC".
Thank you for the clarification. I'll be sure not to order the snow prep, and get a in-line plug for the front of the bed.
Scott
In case i do not get the chance later. I want to wish everyone on TDR a safe and Merry Christmas and Happy new Year.
Scott
I'd get the HD Snow plow prep just for the skid plate and 220 amp alternator, and if I remember from my numerous visits to Oahu over the years it was always snowing :-laf. Merry Christmas!
I would order both of these packages as you are looking at a slide in camper now, but, the truck can handle a lot more camper. you might want those option just in case you move up to a larger camper. My $0.02. Kenny Irwin
