This is in response to many of the above posts. I started with the Banks plate as well and had a difficult time adjusting the arm correctly, and with EGT's. You can put any plate in any pump, you'll just have to adjust the throttle arm and timing to match how you're running (if you want to run advanced timing, you'll need more power or the engine will sound like it's missing, too lean). The charts you guys are talking about have numbers for a plate installation alone, no other mods, so if you're bombing with other stuff, those numbers are a wash. You'll be well above them. I have a #10 plate now and it's perfect. When I put it in, with 16deg timing, it knocked a little (not enough fuel for that much advance) so I slid it forward a skoosh and it runs great. For any of the aftermarket plates, they're pretty much all flat at the top and therefore, at WOT, they'll pretty much all go to max fuel. The bottom part of the plate will define the driving manners at low speeds, rpm and boost. The #10 is may favorite for around town and getting on it. I've tried the Banks Ottomind, #8, #10 and one that I ground down to a #0 profile. Love the #10, forget the rest!! Want more power, slide it forward. I have never removed the intake to get to the plate, I have the twin intake as well. It takes me about 10 min to do the job. It's tight, but can be done without removing the shutoff solenoid and just lifting the pump afc housing out of the way. Just don't forget to replace the dip stick afterwards!! Easy cheesy!!
