outlook monitor
Clash of the Titans ... 12V, mid 400hp big singles
Effect(s) of changing compressor trim on map width/size/quality
What is the purpose of this? Bully Dog says it is compatible with most aftermarket boxes, is it a controller or just another fancy set of gauges?
it is basically a fancy set of gauges, but it can defuel any engine by telling the ecm boost is low... ie: egt gets too hot, and boost actual is 35lbs, bullydog monitor tells ecm boost is dropping to say 25lbs and ecm will defuel to limit smoke, and defueling will limit egt
it works something like i stated. . i am going by memory as to how i read how it worked
