HRDROKN said:I wonder then... . if my voltage was low, this may have effected my speed correction box? Are they that sensitive to input voltage?![]()
Yep. Low voltage will cause weirdness to ensue, just as bad grounds will introduce gremlins.
Slow launch with manual switch? The 46RH will not allow OD unless it's already in third gear
KOG said:If yours holds in OD it sure would make for one verrrrry slooooow launch.
I think the 46RH and A518 are the same critter, are they not? Just different labels.
That is why you can add more fuel, silly:-laf
DP
Funny guy, huh? Tell ya what, lets try it on your mom's truck and we will tell her it was your idea. Think it would still be funny? :-laf :-laf
Yep, my 46RH shifts normally with "mystery" switch in the "on" position. As I stated it will shift 1,2,OD (engages OD as soon as the 3 shift occurs). Downshifting is OD, 2,1. Downshifts at normal speeds to 2 and 1 at both part throttle and stops. Shop manual indicates that this is the only way a 46RH can shift. Unless the 47 has a different valve body, whcih seems unlikely, it SHOULD shift the same way. I don't have a shop manual covering the 47 so cannot verify that. I was sort of surprised to find that the 46 worked the way it does, but it sure makes using a manual switch less hassle. I don't use OD on cold starts (PCM is programmed to not OD until engine is up to temp, probably a good idea, helps to warm engine faster), and have to manually shift it for heavy loads (towing) or highway passing (no third gear with switch on). Otherwise I can just switch it on and leave it on for routine driving after warm up.
I just bought a 91. 5 W250 4x4, it says it has the A518 transmission. I am having the same problem with no O/D, the light "lights up" on the dash when pushed for off, but nothing happens. I need overdrive as I travel the interstate A-Lot!!
Where can I get this info on the mystery switch(I've forgotten)? And does the A518 have a lock-up convertor?
I have a 97 with the mystery switch and I love it!!
Mikey
