Engine/Transmission (1998.5 - 2002) Overdrive
Is there a way to change the default position of the OD. switch to overdrive OFF instead of ON? That way it would be off untill I decide it should be on!;)
I did it.....
Seemed I was always forgetting. So I put a relay in to send a ground pulse to the wire coming from the steering column. I triggered the relay with the jumper they put in for the clutch switch. 10 minute job and now it defaults to off.
If you want more details E-mail me at -- email address removed --
Garrett
I did it to!! The only thing I dont get is why it has to be a 24v relay?? I grabed the one out of my race car for the fuel pump(12v) just to try it and it worked fine!! I suppose I will put the 12v back in the car and talk to my elctronics budy to get a 24v one. Oo.
