I put a bucket below the normal fill hole and removed the bolt. But surprise surprise oil did NOT come gushing out! Hardly a dribble, so I added a couple squirts from my little oil can causing oil to come gushing out. Re-installed the normal drain hole bolt.
Removed the top bolt from the adapter plate and squirted a couple three squirts before the oil started gushing out.
Does not make any sense to me. These two holes must go to different parts of the transmission. Hope you fellows know what you are doing to your trucks because I sure do not understand what I am doing to mine.
The transmission has been working fine since the dealer replaced it free 100,000 miles ago but I guess a new transmission oil seal is required. I do not pull or haul any heavy loads.
I wish I knew where the 2. 5 quarts of oil I added this PM went.
