I just replaced my overflow valve, however when I received it from the vendor it did not come with any washers. The original one had what appeared to be a rubber washer on the bolt head side of the banjo. I couldn't tell for sure if a washer existed on the pump side. I decided to get some copper washers and use them. Was this a mistake or will I be alright. I have driven it this way without problem, but I changed the supply and return fuel hoses and I just can't get this thing to prime. Probably reaching deep on this one, but I'm getting desperite to get this running again. I've tried all the tricks for bleeding the system, and have gotten it to run, but after a few minutes it dies again like it's run out of fuel. When I remove the filter, it is only about half full. At any rate, I've posted in the 911 forum for help, but was hoping for any new ideas.
