cluckmaster said:so, is the TST overflow valve the exact same part as the replacement bosch, or does it flow a higher pressure? If it flows a higher pressure, is that an advantage?
bmoeller said:
ttbird said:bmoelller
Where can you buy this bosch part? Have looked around but get no results at any bosch part place I've tried. Any help would be appreciated.
Thanks, Tom
DESL PWR said:Timebomb,
You mentioned updated overflow valve, anything different from the original?
