I'm happy with mine
It works as advertised. Temp is right on
and I'm a gadget nut so I'm always using
it.
My previous Cummins Ram 3500 did not
have the overhead computer. The over
head console was there. I am a Ham
Radio operator. Needed a place to mount
the control head of my Kenwood TMD700
and the plastic filler panel made a perfect
mount to drill in!
When I had the dually I used a gadget
that I bought at a truck stop for outside
air temperature readings. It has an LCD
display and switches for inside or outside
temperature and clock and beeps when
it gets to 32 degrees or lower if you set
it to do so. There is a long wire with a
sensor. I routed the wire to the front of
the radiator support and used silicone
to secure the temp sensor away from
the radiator. It worked great while
moving down the road.
-Chris
