If your truck has 4 wheel ABS the Abbott ERA will keep tripping your ABS light. If your truck has only rear wheel ABS it will work fine. Basically it taps into the rear wheel speed sensor circuit which is also the rear wheel ABS sensor circuit. With 4 wheel ABS the Abbott ERA is correcting the rear wheel sensor signal while the two front wheel sensor signals remain uncorrected confusing the ABS computer, hence the ABS light keeps going off. This was my experience with my truck. The speedo was correct, but I'd rather have my ABS working. I ended up sending it back for a full refund. If you do order one, order from Rickson Truck Accessories. They sell them cheaper than Abbott does. Good luck -Glen
1998 12 valve 2500 Quad Cab, A/T, 4. 10, Deep Amethyst, 4. 5" Skyjacker Double Flex lift kit, 36. 0"x14. 5"x16. 5" TSL Super Swamper radials on 16. 5"x9. 75" Weld Typhoons, Speedliner spray in liner, Raven high rise cap, J&J stainless steel Nerf-N-Steps
