2nd Gen Non-Engine/Transmission Owners with 100K+ miles
Engine/Transmission (1998.5 - 2002) Expected Power?
Question for all you guys that did multiple front end parts replacements, especially track bars... .
What were the most common symtoms or did the service dept. tell you they were bad?
Mike
I thought I had it bad , but after reading all of this I think I'll keep my hunk of junk!!!! After about 60000 miles I put on the first fuel pump and starter,70000 second starter 72000 third starter . At about 80000 Icould not align my front end REBUILT THE********** front end . Gas gauge sensor,rear wheel seal transmission my fault 2nd transmission NOT my fault . after all this Istill love my DODGE !!!! So far jbutts
140,159 miles today.
24k; crankshaft position sender
65k; 5th gear nut
96k; new lift pump
97k; new front brakes, rear ok yet
99k; new front axle seals
112k;new AC compressor
118k;new clutch, T. O. brg, pilot brg.
(clutch was only 45% worn. )
Truck is running like a new one. Front end still tight. Excellent oil sample reports.
563,000 miles
Ball joints- all 4 twice
Tie rods- all of them 3 times
Brakes - a lot, I can't even tell you how many
One rear axle seal
One front axle seal
Shut off solenoid
Starter contacts
Fifth gear nut (replaced with mainshaft and nut)
Transfer case
vacuum pump
Alternator
Drivers door pins
Front engine oil seal
PS pump
Steering gear assy (3 times)
Steering shaft
Driveshaft carrier bearing
Front steering U joints
Front hub assy - both sides
Lots of shocks until I went with the Edelbrocks
Radiator (and in need again soon)
Fuel return line - the steel one under the intake
Fuel gage sending unit
Wiper motor (today - in the rain no less)
Still not too bad in my book... ... .
close, 98k most under extended warr. :D dip stick, water pump, leather steering wheel, steering column, 1 stock, now borgenson,track bar,shocks, 2 sets of brakes, pwr door lock switch, trans on borrowed time:( a/c evaparator diagnostic done today,(BAD). Not too bad IMO, motor is a work horse. PS: anyone that has had dash apart to replace a/c core tips would be very appreciated. Thanks
Catch me If You Can
Just got back from Sarasota, Fl. 612,000 miles.
Starting to have clutch pilot bearing problems again. . Oh well, i'm getting go at it. :D
The pic is not me. hehehe. :p
