P0071 Ambient Temperature Sensor Performance / Rationality
P0633 SKIM Key Not Programmed in PCM
The P0071 generally because of the sensor on the air box it think. Had it unplugged when started, dirty, etc. This code should clear on its own if the problem is no longer there.
The P0633 code is a little weird. I have had that code on mine for over a year. My scanner can not clear this code because it is a DC stored code. The dealer tech said it just means that at one time the chipped key did not register correctly with the computer and that many things could cause it. He said not to worry about it, it is stored and would just show that at some time in the past there was a chip key error.
