Would anyone out there happen to know what the Mopar part number for the clutch disk is? Getrag 5 speed 1990 truck. Thanks
bgilbert said:Does the new one say Sachs on it? Sure you didn't get sold a 2nd gen 5sp clutch?
Paychk said:BTW How many miles are on that 12 1/4" ?
14 dampner springs Sachs
8 dampner springs Luk
ScottLowry said:You can upgrade to the 12 1/4 inch clutch it has a higher clamping force. I did and it's been great. Clutch Kit was $239 with bearing. I can give you the number to the place to order it from if you want.
Scott
mysteryman said:The 12" clutch is no upgrade at all ! The only thing that improved was Chryslers profit margin ! The only reason the clutch was really changed was because we learned that the expensive 13 clutch that we used in the 1st gen trucks was not wearing out ... . So it was decided that a cheap stamped steel cover would work just fine and that less friction material on the disc caused less chatter and wore out much faster ... ...
The fact of the matter is that many of the 1st gen trucks components were over built because we did not really know what was going to happen in the field yet..... By the time the second gen came out they had all the data needed to know which components could be cheapened and which needed improved to make it out of warr.
I hear many talk about changing out your 13" clutches to the double disc or other hot rod clutches... . When or if you do please let me know before you throw away your stock 13" clutch... . I would like to buy it from you.....
