I have a 2001. 5 ETH w/ 275's, Banks Big Hoss 5 Module, Banks Quick Turbo, BHAF, 4" exhaust, Ray's banjos, Carter pusher pump and Pac Brake and Friday, on hard acceleration set off the check engine light. This was the first time with the above mentioned enhancements that I have set off an error code. After the on-off, on-off, on-off key operation I got the above error code P0121 which according to the list of error codes at http://www.troublecodes.net/chrysler/99-01trk.shtml this indicated two probable causes:
1. TP sensor voltage does not agree with MAP and
2: Accelerator position sensor signal voltage too low.
Anyone know what the probable causes for this could be since the electronics are above my "old style" mechanical ability?
Do I have to replace the throttle position sensor again? Had too about 40K miles ago.
I was told by one person that it indicated a mismatch between the air and fuel flow.
Looking forward to comments
John Styer
John Styer
