P0148
High rail Pressure
06 48 RE shift modes
the 2006 manual says p0148 is high pressure common rail checksum possible causes are
  • fuel leaks
  • fuel control actuator
  • fuel pressure sensor
  • cascade overflow valve
  • check valve damaged or blocked
  • fuel return lines obstruction,damaged or debris
  • lift pump flow
  • air in fuel system
  • leaking fuel injectors or high pressure connectors
  • pressure limiting valve
  • high pressure fuel pump
  • intermittent condition
  • hope this helps you
also says other dtc's could be present
