P0192 is "Fuel Pressure Sensor Voltage Too Low"
Possible causes:
-Fuel pressure sensor
-Supply circuit shorted to return circuit
-Signal circuit shorted to return circuit
-Signal circuit open
-Supply circuit open
-Signal circuit shorted to ground
-Supply circuit shorted to ground
-Bad ECM
Bascically, either the pressure sensor has gone bad or there's a wiring problem between the sensor and the ECM. If you want a copy of the complete test sequence, PM me and I can email you a scan of the diagnostics manual.
If I had to put money on it, I'd bet your pressure sensor went bad.
-Ryan
