Engine/Transmission (1998.5 - 2002) P0216, engine quits while putting it into drive or reverse but it is NOT the VP44 HEL
Engine/Transmission (1994 - 1998) Another one on pump timing
2nd Gen Non-Engine/Transmission Cracked wheel. arggh
Truck runs fine when cold after it warms up, it quits when going into reverse or drive(unless you keep the RPM's up. Had the 0216 code. the dealer replaced the Pump and lift pump. No help, but the new pump had a new p 0216 code so he replaced the pump again. same problem again but ATTM no code. He thinks it might be fuel. I don't or every Dodge in Alaska would be in. I had a factory program loaded into it 5 years ago so when it gets cold it shuts off 3 injectors and raises the RPM's to 1200
Anyone else have this an what was the fix.
what kind of tq converter do you have. I was reading a while back about a guy with a suncoast triple disk that was having stalling problems when going into reverse. other than that I dont think I have anything helpful. mine will buck going into reverse if I dont let it idle for about ten seconds before shifting. when it is doing it my fuel pressure gauge is bouncing between 5 and 15 psi. hope this kinda helps.
mark
