P0236 code. How do I fix it?
OIl Analysis
A2's are in Diesel Tune Inc. has 9 of them
I know this is one of the turbo errors P0236 TC Boost System (according to the allpar.com Chrysler error codes, web site) or it could be P0236 Turbocharger Boost Sensor A Circuit Range/Performance, either way, I am hoping one of you kind gentlemen out there can help me determine how to make it go away, permanently. I have used my OBDII scan tool to remove the codes, but I would rather resolve the problem.
Any help you can give will be deeply appreciated.
:confused: :confused: :confused:
P0236 - MAP Sensor Too High Too Long
Could be a fried MAP sensor or your Xzillaraider. Only way to tell is to experiment with the Xzillaraider.
-Ryan
I had the same code problem you did. I determined it was my Xzillarader XZT. I called Quadzilla and got a return number and sent it back and they had a code update for it. If you have an early box like I did, this might be your problem.
Good luck, Wayne
