can someone please explain in detail( to help me better understand) what does the p0336 code mean, i just replaced all the sensors a month ago, im tired of messin with this truck---its allways something... ... .....
MMeier said:Crankshaft position sensor code Wade. My rig will usually set it when I can't get above 1100-1300 RPM for a bit while moving( stop and go, traffic jams, you get the idea. Around here it seems to be tied into the TST box for whatever reason. Seems to come hand in hand with another code at the same time, if your engine light is on, it should go out after like 10 key statrs or something like that.
RDyson said:I got the code on mine when I was running a Rokktech sensor with my TST. Too much timing I guess. Since I've taken the sensor off, no codes.
