my truck seems to run fine,mabey a little ruff at idle but it throws a p-0628 code. cant seem to find anything on line to help,just want to address it before the truck shows me what to do.THANKS,AJ
early 2004Code is for low voltage at lift pump. Can you tell us what year truck?
NO its a 520 ci RB with a 1050 dommy runs mid 10,s at 4,129 lbs (with my big carcass in the seat) its a street car.Is that a true 440 six pack ?.
129,000 i just put a brand new lift pump on it.mabey i should start back tracing wires,i assume it should have full charge vlts to the pump?Ok if the lift pump has never been updated to intank then it should be mounted on the back of the filter housing.. It's probably bad. How many miles on the truck?
also i cant seem to find a fuel pump specific fuse in the box.NO its a 520 ci RB with a 1050 dommy runs mid 10,s at 4,129 lbs (with my big carcass in the seat) its a street car.
could this mean there is a prob with the ECM.If i can trace the fuel pump wires back to the ECM mabey there is a bad wire?If it is like the 2nd gen there is no factory fuse. The pump runs through the ECM.
