P1223
Has anyone ever had a van Aaken box fail?
WTS light is comming on while driving, I've read some posts about it but what I need to know is if I need to park the truck or can I still drive it? Is it also turning on the Grid Heater? If I can drive it, is there any way to diable the chimes until I can get to a shop?
Need some fast help as I'm supposed to leave for Thanksgiving trip tomorrow.
Depends on what is causing the problem, injector wear, electronic glitch, LP, or injector failure imminent. When the electronics are telling you there is a problem reliability becomes a question.
Yep, This light in Most cases on 06+ is indicating the back leakage rates are ABOVE programmed Parameters, My guess is you do have some time before hard starting, if you have this light with long cranking time is short... ... I would recommended ALL CR owners to carry Starting fluid if they feel comfortable using in in emergency starting.
