Engine/Transmission (1998.5 - 2002) p1593
Engine/Transmission (1998.5 - 2002) Oil leak behind oil filter
Engine/Transmission (1998.5 - 2002) computer settings
How about this one!
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM.
I think I have a line burned out in my odometer which would make my 1593 a 1693. If this is it, how is this fixed? What is "DTC"????
BTW, I never changed my PCM/ECM when I swapped the auto out. I think this could be the reason for it cuttin' out from about 1800RPM to 2200RPM. If anyone has any spare ECM/PCM they would like to lend me to see if this cures my problem, let me know! :D
