Originally posted by csutton7
I believe our friend Brandon can eliminate codes from our
chris sutton
1999 2500 24v qcab longbed 4x4 red sport w/ all the options 'cept plow pkg,red camper shell, 4:10 detroit locker in rear & front ARB, 5" skyjacker lift w/ 35" BFG MT's on 16. 5x9. 75 Weld rims, black smittybilt step bars, black 3 pc. bug persuader,
black lumber rack, camel leather int. w/ mb quartz spkrs and JL Audio twin 10"sub stealth box under rear seat , PE EZ, DTT 91% vb & tc, mag hy-tec transmission pan, B1 turbo,
red magview diff covers front & back, SPA pyro/boost&fuel pres/oil temp on "A" pillar,AFE mega cannon,Aeromotive lift pump gravity fed w/an Aeromotive prefilter,-10 fuel lines to pump and -8 all the way to the VP44 then -6 fitting @ VP44, Racor fuel filter ,separate return line w/ an Aeromotive regulator, Bully Dog 5 injectors or DDIII's, Jardine 4" exhaust,ATS manifold, hot,hot Power Edge, red L&L ladder bars, skyjacker dual steering stabilizer, red Cummins valve cover,ATP hood blanket, red Confer axle truss/pumpkin protector, adjustable high idler, turbo shut down monitor off of SPA, upgraded transmission output shaft and installed a NV241HD transfer case & a red DT track bar,front receiver hitch, 4 Bilstein shocks on the rear and 4 on the front(thanks to Brandon and Brandon), 15. 8 @ 91mph(no boost at launch, crappy reaction time and about a 1000lbs in the bed w/ DDIII's)--sled pulls=4-1st place, 1-2nd place, 1-3rd place and 2-DNF---the above is a big fat lie I really own a totally stock RAM---Special thanks to DTT, Performance Diesel.net, Diesel-Central.com and Brandon & Danelle
trucks---contact him for further info-----chris
