P2000 & P191 Codes
radio recommendation for 2018 2500
Blue smoke need help
22012 Ram 3500 Diesel - 125000 miles
Check engine light on. Used my OBDII reader and it shows P191 & P2000 codes. I cleared the codes and after three weeks the P2000 code has returned. The P191 code is not on.
A google search tells me that this may be an expensive fix. Possible catalytic converter.
Any and all thoughts appreciated.
Larry in Yuma, AZ.
What are the Common Causes of the P2000 Code?
What are the other symptoms that you are experiencing? When was the last time you had a software flash done? Just because you had a code pop up, doesn't mean it's gonna hit you in the wallet. Batteries can cause gremlins as they age. More info needed to help with fix. We're here to help one another with just such issues! :)
