All,
I have fallen victim to P2262 and am a little curious about the possible causes. I originally had the code appear in late October. The dealer then determined the fuel in the oil and the turbo failure were due to fuel contamination. To get a new turbo, the dealer said I had to have the 67. 5k mile service done (because of engine hours) to clean the EGR and change the crankcase filter. That work was done as well as a fuel tank cleaning, oil change, and fuel filter change.
The problem has now returned and a different dealer seems to want to go down that same route (clean the tanks and do a CRC injector flush). Is it possible that contaminated fuel can lead to the issues I'm seeing (P2262 and oil way over full)? I'm not that mechanically inclined, but isn't that what a fuel filter is for? I should also mention that the latest dealer had the technician run a return test on the injectors twice. The first time, the results showed double the amount of returned fuel. The second time, the results were in spec. What gives?
I really want to get my truck back on the road and don't want to be taken advantage of by the dealership not wanting to pay for the warranty work. It seems to me that they are just saying fuel contamination without any real proof that is the cause. Can anyone help?
I should also mention that my truck is an 08 2500 6. 7 4x4 with 54k miles and is completely stock. Please help.
