The earlier trucks used to throw the code sometimes at high altitudes.
I would buy that.
Elevation here is 1371'. When I started the truck this morning, the engine light was on. I moved the truck about 200' and shut it off. Started it back up, engine light is off. I don't know?!
.... How does Moisture get into the sensor lines? These lines are on both the in and the out sides of the DPF. It's my understanding that the DPF is dry exhaust going through it. It's in front of the SRC. So how did moisture get into the sensor??? The TEC said that they have seen this problem a few times before. Any thoughts ? Should I keep this sensor part number 1 68085750AB on the shelf ?
Normal hydrocarbon based fuel combustion produces ideally CO2 and H20 as exhaust... all other things that come out are the reason for all the emissions controls. There is ALWAYS water vapor in the exhaust. When you do many short drives where the temperatures never get very high in the entire exhaust, the water vapor condenses in the cold exhaust pipes, and is sometimes literally seen dripping out the tailpipe.. that is where the water comes from.
