Engine/Transmission (1998.5 - 2002) P4601hp Dead!!
2nd Gen Non-Engine/Transmission O'head Reading Lamp Bulb
2nd Gen Non-Engine/Transmission Front Axle Leak & Trans Leak?
Here we go again!!:mad: I have the Carter P4600HP by the tank and the P4601HP in the original spot. I run both with a relay that gets activated by the stock wiring. Everything was going good. Have had the system in for about 2 months and it gets about 22psi at idle. Went on a 400 mile trip last night and it worked great, have been on a lot of trips and it works perfect. Then I get up this morning and get on the highway and I look at my "A" pillar and my idiot lights for low fuel pressure are on. :eek: I look at my gauge and I only have about 5psi. The P4601HP is not pumping but the motor is running. So I pull it apart and the shaft from the motor fits inside the part that spins with the vanes. Well it is held in with a little of plastic that is now broken into three pieces. :mad: Has anybody else had this failure with this set up? I tried finding a contact at Carter so I could bit** but I guess they don't want to here from us. I think maybe it is the high fuel pressure so I might try to put a fuel pressure regulator in. Any Ideas? My wife says I've had a lot of problems with this truck. I said it is my fault and not the truck.
Jon T
Plastic parts where metal ones should be drive me nuts :mad: . Sorry about your pump, but thanks for the heads up.
Press your mute button when the wife complains. :D
