Details here: TDR Privileges
Is there a book or past thread available that shows the different adjustments that can be made to the P7100 and what each adjustment does. I'm not talking about adding or sutracting parts, just what can be adjusted and what the adjustments do.
Go to www.PIERSDIESEL.COM and click on "technical" on the left side. You will find pics of governor lever adjustments that may be necessary with some plates. You can also search for "idle adjustments" and see what comes up. As far as internal dimensions and trade secrets for more power, good luck! Most of what I have seen posted here is just good, reliable information that most of us can use for everyday maintenance and repair. HTH
