Engine/Transmission (1994 - 1998) P7100 adjustment points ?
Engine/Transmission (1994 - 1998) Any one running a M11 turbo??
Engine/Transmission (1994 - 1998) TSB concerning auto trans?
Is there a book or past thread available that shows the different adjustments that can be made to the P7100 and what each adjustment does. I'm not talking about adding or sutracting parts, just what can be adjusted and what the adjustments do.
RonA
RonA,
Go to www.PIERSDIESEL.COM and click on "technical" on the left side. You will find pics of governor lever adjustments that may be necessary with some plates. You can also search for "idle adjustments" and see what comes up. As far as internal dimensions and trade secrets for more power, good luck! Most of what I have seen posted here is just good, reliable information that most of us can use for everyday maintenance and repair. HTH
Ronco
Not looking for any trade secrets. It would probably be best to contact Bosch. They might have a book I can buy.
