Engine/Transmission (1994 - 1998) P7100 governor studs help
Engine/Transmission (1994 - 1998) Camshaft swap Instructions
Engine/Transmission (1998.5 - 2002) Valve Adjustment Help?
Looks just like mine did after an internal failure (rack stop pin broke).
New parts only! Don't try to straighten it. You might be successful, but it has a high probability of catastrophic failure at speed.
FWIW: my local Bosch shop extracted just over $1300 from me for a pump rebuild and calibration before it was all done, and I R&R'd the pump.
Sorry, man.
-Jay
How does this happen? I know what JGK said happened to his but is that what's happening to everyone else? Just want to know so I don't bend one of mine.
Scott
this happened becouse the donor truck of this engine had a fire and the timing pin which is a metal piece surrounded by platic melted in and eventually hitted the studs. i installed another pump i got from afriend but has less power its a 190hp and mine was a 160hp but it seems has way less power makes way more noise, maybe its timed wrong.
Jordan,
No, I've always had a plate in, and at the time it was a stock (unmodified) TST #10 so it can't be blamed on a custom plate cut too deep.
The tech said there was nothing he could see that caused it. He said it does happen on a rare occasion. He's seen a few others over the years. If I remember correctly, I think he said when the engine is shut off, the rack bumps the pin at fuel shut down.
-Jay
I had the same thing happen to mine, only thing different was it actually came off and cracked the governor housing. #@$%! Can anyone say new pump.
