IIRC -P7100 pump, inj. lines, lift lump, fuel supply lines from LP to filter and from filter to IP, gear case, gear case cover, front crank seal, you must r/r the camshaft in order to r/r the gear case.
In a nutshell its a real PITA and $$$ unless you are pulling the engine for other stuff like machine work. At least that is what I have been told.
