OK, I've read just about all I can on how to time these. I got the tools, but I need to figure out a few things before digging into this.
What I'm picturing is:
1 You find TDC
2 mark it on the damper
3 put timing tool in #1 DV
4 rotate engine to where you want timing on the dial indicator
5 Pop timing gear off of taper on the camshaft
6 rotate enging to TDC
7 Clean taper on cam thoroughly then torgue nut to 145 ft/lb
8 assemble.
Do I have this right?
I'm so used to timing gas engines (40 yrs) I'm having a hard time visualizing it.
TIA
1 You find TDC
8 assemble.
TIA
