HGreen,
How would the clutch switch prevent this though? It seems like even if you had the clutch swtich, the instant you'd let off the go pedal, the brake would activate still. Or would you have to install the shift-mounted switch to turn it off while you're accelerating, then back on while you're deccelerating? Would that fix the issue without the use of a clutch switch?? I figured $35 was a little steap for a simple shifter-mounted switch that I could go get from a semi tractor salvage yard, but I think those are mostly air switches, where the one with the pacbrake is probably electric (this is just my assumption, based on the fact that the pacbrake ties right in with our truck's complex electrical system).
NWroten,
I recommend contacting Jelag. He has been very helpful in answering my questions and offered me a price that only one other shop (which happens to be managed by a close friend) could beat (and only by 50 bucks). However, I will probably end up going with Jelag because of his customer service. The service from the other shop would be questionable. Jelag even offers free shipping!!!
My last question for members reading this post: Do you guys find exhaust brakes advantageous while you're running unloaded? The advantages of running one while towing is obvious, but I assume they are just as helpful for use when running empty? I have a 6 speed and figured it would require a lot of shifting to do this, but I heard from one member that he could come all the way down from 60 to 5 mph without ever touching his service brakes and do it in a reasonable distance.
