I just installed my BD brake last weekend. I started on it at 12:30 Sunday afternoon and it was finished at 4 PM. And I was getting over a bad cold that had me down all that morning and the day before. I couldn't stand wasting the whole weekend so I put in the new brake. If I hadn't felt so crappy it may have gone faster. The install is very straight forward. The hardest part for me was getting the switch set properly because I had to tweek the switch mount a little to get the adjustment out far enough to where I wanted it. I've been using it all week and it works great. Don't forget to set the hold back pressure. I set mine at 25 psi at idle, it came set at 15 psi.
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction
