Pacbrake PRXB w/ Banks High Ram elbow?
drop in air filter
threw a code today i have never seen before
Does anybody have an easy fabrication fix for mounting the compresor for the new PRXB with the interference of the Banks High ram? The PRXB is designed to use the long bolt of the stock intake elbow as the 3rd mounting point, but it won't work with the High ram. I have a mount drawn up on paper, but before I put tools on steel I was wondering if someone else has done this yet?
I probably will buy a Pacbrake sometime soon, and I have the Banks High Ram intake also,, I would be interested in what you come up with if anything. I guess I could swith back to the original intake as a last result, but would rather not if possible.
I'm not sure if this will help as I could not tell what truck you own..... I have an 05 with the PacBrake and Banks High Ram..... I was able to modify the existing bracket that came with the compressor by redrilling the holes and moving the bracket forward..... I did this over 18 months ago and it seems that I had to cut the mounting plate some too... . the mount plate is very close the the upper cooling hose... . No problems with mine. :cool:
