Paging Mr Mopar-Muscle.......
Installing 2 gauges on pillar. Need help and pointers
Pics of Gauges
Just wondering if ya got out to the track today and what the results were? Hoping you chime in here before I leave for work. . otherwise I'll have to wonder bout it all night long!
Did you get an HX40 on???
hey kat , i went to the track , but did not race , was unable to get everything in place to make a run , meaning i had work to do around the house which didn't allow me to install the HX40 , change my oil and drop my trans pan , still haven't done it .
but there was a guy there at the track with a truck like yours ,reg cab 2500 with 4. 10s , he had a blue box set at 50 , BD step 4's and an EZ edge , stock TC , suncoast VB that was hard shifting , line pressure to high and a stock tubo with a 14cm housing and no wastegate .
13. 84 at 95 plus mph , he spanked a GN on that run ...
my trans seems to be slipping , or my gov sensor is gone again , either way i need to get into the trans and see whats up , maybe that 26k with 375 plus to the ground and no trans mods what so ever is beginning to rear its ugly head ???
talked to stephan , fgured out what is helping you surpass me in speed , its the 400 plus pounds less you weigh than me . that guy at the track go on the scale and he said he weighed about 6300 lbs ...
I need to weigh the truck but I bet its around 6500lbs... ... is my guess. Is the race season over for you? have 4 more Sundays to run..... this sunday will run with current setup and practice shifting out of 4wheel drive and see if that frees me up on the topend any.
4 wheel drive?
when launching in 4 wheel drive, how does the 4x4 disengage? do you put it back in 2x4 between shifts? i need some info before i try it... ... . james
So far I have ran the whole way in 4 wheel drive. It just don't sound too happy at 90mph. So next trip to the strip going to work on shifting out some how.
We'll see how it works I guess.
90 mph in 4x4?
THAT can't be GOOD!!
what if ya shifted out after risk of slipping tires?:confused: i spin threw two gears when i hold the boost at three lbs at launch... ... james
Sure it can't be good..... but it works :D I'm gonna wait until I am in 2nd or 3rd before I shift out. I am hooked on the 4 wheel drive launchs... ... ..... I like my 1. 88 60 ft time. So no more 2 wheel drive for me... waste of time :D I've only been to teh track twice. 9 passes total... the 9th one being the quickest... I'm still learning.
Next trip is work on shifting out of 4 wheel at some point to free up top end..... I think I can improve my time with jsut that "change".
no , the season is over unless i go south , not sure how far south though ... going to maryland next weekend , i'll see if the track is open down there , my trans is coming out on saturday for a long overdue update kit .
as far as getting out of 4wd ,if i were to condone such action :D:D ... once you get rolling and out past the 60 ft mark just slip the 4wd lever forward , no throttle lift required :rolleyes: . james , if you have enough power to slip those 4 rears after that far you need slicks :D:D
that guy last sunday was using 4wd the whole way down also , i told him what to do , didn't seem to make a huge difference , i think but he did go from a 14. 0 to 13. 8 ... he ran once more and i didn't see what he turned . i did let him drive my truck , he was impressed with my TC . he wants one next , his truck with the TC and slicks would be knocking on hi 12's ...
