dvieira
Hi. .
the actuator which controls the front panel/ defrost door has gone bad for the second time in 2. 5 yrs, seems to be getting oil and losing vacuum, is there a cure for this, dealer has one coming in tomorrow for $25. 00, it's the one almost next to fuel pedal, held on with 2 phillips screws, it's easy to get to /replace, but today
happens to be in the high 90's and it goes out.
again does anybody know of a cure for this oil in vacuum lines.
also does anybody know what a vacuum pump sounds like when it's gone bad or going bad, this might be related to above problem, but the pump sounds sorta like a siren when first starts
then quiets down, only after i give it pedal.
thank you
dave
thank you
dave
