I 've just purchased a 1997 3500 4x4 with a cummins 5 speed. I knew there were a few "items" that needed repaired, but I negotiated them into the purchase price, and decided I could fix them myself. Number 1, is the parking brake light will not go off, it stays on all the time. The parking brake is fully released, but light stays on. I even manually triggered the switch located at the top of the parking brake pedal, but it made no differance in the light, it stayed lit. Parking brake does work fine when it is engaged, and fully releases. I dont have a service manual yet(I have one ordered) so didnt know what to check. I have had some suggestions from others in other forums ,but so far nothing has helped. Number 2 problem, is the cruise control doesnt work. When the on/off button is depressed on the steering wheel, the CC light beside it "flickers" once, then goes out. If it would stay on, then I could test the cruise on the road to see if it worked, and if not, then probabaly start looking for the vacuum leak, people have said develops beneath the battery. But when the light not staying on, I didnt feel the need to check the battery area, yet. It has been suggested to remove the steering wheel cover(I dont know how, yet), and check the "keypad" or "switches" for a faulty and/or broken wire. Does anybody have anything to add to this problem?
thanks,
coadman
thanks,
coadman
