PC12Driver said:There is no reason for a truck NOT to roll if it is left in gear w/o the parking brake set.
If the transmission was out of the truck, you could put it in first and spin it via the output shaft. It's just a couple of shafts and straight gears - there's nothing to lock it in place.
We know we can hand turn these engines over fairly easily with a barring tool, or even with the nut on the alternator. So there's nothing locking the engine in place either when it's off. Maybe an occasional bump of compression, but that leaks by fairly quickly (gas or diesel, every engine WILL leak down).
So there's nothing magical that will lock and hold your truck in place if you park it in first. You're just working against friction and a bit of compression that will leak down. Granted, first gear gives that friction and compression a huge mechanical advantage, but with 7k lbs+ of truck it's just a matter of time before it rolls.
PC12Driver said:Roll, creep, move, whatever. The truck won't stay where you want it to if it's parked on an incline if you assume 1st or reverse is the same as Park. And once it bumps past the compression stroke it was sitting on, then you're dealing with inertia too. That'll easily turn "creep" into "roll. "
JHardwick said:My truck "rolls" @ 2MPH while the engine idles @ 750RPM, it's not likely that your gonna see an 8,000# truck spin a dead engine at 750RPM. More likely the truck will "creep" from one compression stroke to the next as they bleed off.
JHardwick said:I've been in the habit of using the e-brake for years, auto/manual, flat/incline, no matter. I've found that this keeps the cables from rusting and siezing to the point of having no e-brake when you really do need it.
JHardwick said:You don't have to tell me, I use mine all the time. I was just pointing out that a truck rolling down a hill is a lot different than a truck creeping down a hill.
PC12Driver said:Isn't the end result the same?
NUKEMAN said:I can't believe this has gone on for 4 pages! I mean, c'mon, JUST USE YOUR DAMN E-BRAKE!
There, I'm done.![]()
BGott said:I have learned to never leave a vehicle in gear when parked. Old diesels had fuel cut- off knobs, once you had killed the truck and released the knob vehicle creep or a bump could start the truck. As a mechanic I've seen lots of people get into cars and trucks and start them and then let out the clutch, not knowing that the thing was in gear. Or seen a tech bump a solenoid to bring a timing mark to the top and have the vehicle jump.
