poor rear brakes?????????
I read your comment about the rear brakes being poor on your truck... ... I am sure yours are most likely are... But have you ever really wondered just why that is ?
It really is not the brake system that the truck has..... The 357/358 bendix drum system has been around for a long while and used at one time or another by all the car companies. . The real reason most of you have poor breaking is because your using poor and or incorrect friction material on your shoes.....
Another reason is because the ABS system that is used on the rear brake systems on the first gen trucks is worthless... . At Chrysler we used to call the system the ASB system which stands for Anti Stop Brakes... . LOL
Some years back all the friction material manufactures stoped using ASBESTOS in their friction material..... Most of the friction material being used now on the 357/358 shoes does not have the correct properties to make the brake system function as it was intended to do... The friction coefficient is low while the heat that it generates is high ! With out going into great details on friction materials I will just say that you are making 3 times the heat and only getting 1/2 the stoping power that you would normally get if you were using the correct friction material that was intended to be used with this system. .
The only friction material I have found that is currently being produced that comes close to working properly is manufactured by a company out west called Performance Friction... . I buy this lining from them and put it on my shoes... . While it is a good material. It still is only about 85% compared to the original Bendix asbestos lining ... It also wears out twice as fast.....
There is an article in the current TDR magazine I got last week that explains friction material/brake system properties..... Refer to it for greater details...
As for the the ABS system... There is a large ABS valve bolted to the inside frame rail just about over top of the rear axle... . There is a brake line running in and another running out..... Cut these two lines and connect them together... Remove the valve and toss it in the trash... . Then find the big black box that sits behind the glove box and unplug it..... Your brakes will stop much better... . Most of those valves are malfunctioning by now anyway and they never worked properly when they were new... . They were also designed to operate with the correct friction material... ... That material is no longer available.....
If your hauling heavy trailers you will really notice a difference in how the truck stops... .
The information above you use at your own risk... ABS brake systems were designed primarily for people that do not know how to drive... So if you are one of those people that do not know how to drive or do not know how to work on break systems . Please disregard everything I have mentioned.....
rlyons said:
Here is an interesting artical on brake rotors.
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
You may be overheating your front rotors due to the poor brakes on the rear of these trucks. I think I too will use the stock rear cylinders and go with the larger shoes and new drums. My rear brakes have always been poor but I pull a 5th wheel trailer which has it's own brakes.
