Engine/Transmission (1994 - 1998) parts changed & broken
Engine/Transmission (1998.5 - 2002) 24 valve adjustment.
Engine/Transmission (1998.5 - 2002) Turbo help
well heres a run down of parts changed orbroken :eek: (by mechanic):
changed:
head gasket & head gasket kit parts
front seal/ sleeve installed (had to :-{} on how that was installed)
valve cover & front cover gaskets (checked on kdp tab)
oil & oil filter changed/ coolant flushed & refilled
injector cap o-rings
(head worked by machine shop) :) injectors good
belt
broken:
water temp sensor $25
front seal $60
5 push rods bent :{ $40 :mad:
about $700 spent, well there goes the intake/exhaust & gauges :{
dt :cool:
DieselTorque said:
broken:
front seal $60
Sounds to me like the guy forgot to unplug the Temp sensor..... Tech's fault... they should eat that..... and the 5 push rods..... sounds like the tech wasn't paying attention when he was torqueing things down and bent them (done it on my first headgasket job)
Josh
